pods question
  • rdgrnr
  • rdgrnr's Avatar Topic Author
pods question
26 Aug 2007 08:58
#166403
I'm wondering what the airflow difference is between the foam air pods and the paper ones? I would like to replace the green foam ones for the chrome ones. It is for my 77 650 project(which is now running nicely)with VM24's and no mods.
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: pods question
26 Aug 2007 09:26
#166410
1) Foam filters can be cleaned and re-oiled to be used again.
2) If you get caught riding in the rain, foam filters (if oiled properly) will repel water to some extent and help prevent them from becoming thoroughly soaked or sucking water into the carbs. Even if they do become wet/soaked, they can be dried out and re-oiled again.
3) Foam filters usually allow better airflow.
1) Once paper filters become dirty enough to restrict airflow, they should be replaced with new ones = $$$
1) Paper filters don't like water, and will either turn to mush if soaked thoroughly/long enough, or will become brittle and limit airflow when dried out.
2) Paper filter material can vary in thickness from diff manufacturers, and even between identical filters from the same (usually cheaper priced) brand, so obviously the same airflow might not be achieved when replacing them when they become dirty.
Better yet, just go with the gauze type media (like K&N) pod filters. They boast having better airflow than both the paper or foam filters do, plus last longer. Sure they're a little more expensive, but you get what you pay for.
Heck, K&N backs their filters with a million mile warranty, so you basically can't lose.
Just my 0.02 worth here, so take it for what it's worth. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
Re: pods question
26 Aug 2007 09:31
#166412
And here's some more good information regarding the various air filters, pros and cons, etc. :)
Air Filter Info
  • rdgrnr
Re: pods question
26 Aug 2007 10:53
#166421
Well, it has the green unifilters on now, so based on the fact that for now, this is an econo-ride, any tips on oiling these as they are really dry would be most helpful.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • rdgrnr
Re: pods question
03 Sep 2007 12:59
#168268
still wondering how to oil these unifilter pods..any info would be appreciated
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • AeroSS_87
  • AeroSS_87's Avatar
Re: pods question
03 Sep 2007 13:19
#168269
Well I would venture to say you could just get a k&n recharge kit and follow the directions they have with them, but I am not sure if the material you have is the same. I just got my chrome pods for like $24 off ebay, so for cost equivalent, it might be better off just doing that. I'm far from an expert though... just giving you what little info I can.
  • rdgrnr
Re: pods question
03 Sep 2007 13:32
#168271
the filters I am using are Unifilter foam. I'm just not sure how to oil these without over-oiling. Thanks for the input though.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • loudhvx
  • loudhvx's Avatar
Re: pods question
03 Sep 2007 13:43
#168273
If you look at suppliers, there are products specifically for foam filters. You nned the foam-safe solvent and the foam filter oil. They are usually in spray cans.
There are different products specifically for gauze filters. Don't use the products for one on the other.
  • rdgrnr
Re: pods question
03 Sep 2007 13:51
#168274
ok will do, thanks
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: pods question
03 Sep 2007 20:00
#168340
UNI Filters have there own service kit especially for their foam filters. Use only their specific cleaning kit.
'85 GPz550(ZX550-A2)
  • wiredgeorge
  • wiredgeorge's Avatar
Re: pods question
04 Sep 2007 06:08
#168399
The cleaner isn't that important. The UNI foam filters can be cleaned with orange spray cleaner and then after dry, use UNI type (brand) spray oil. The can tells you how to apply but basically you mist; don't SOAK. Most people over-oil filters. I also believe that the UNI people tell you not to use the K&N oil. The K&N oil is heavier and doesn't work well on the foam type filters. You can find UNI oil in almost any dirt bike shop.
