Resurection of a KZ650
- MNKZ650Guy
25 Aug 2007 09:18
I could sure use some help. I am still trying to get this 79 KZ650 going. Here's the bike history. 5600 miles, PO parked it after carbs leaked in Spring of 95. I bought it and pulled the carbs, cleaned with simple green and aerosol carb cleaner. OK... start up time.
Bike runs with choke on. Throttle not very responsive. As I sit on the bike, left two
exhaust pipes get hot, right two are warm and can be touched. I pulled the #4 wire and it has spark.
What the heck are the possibilities? Still a fuel issue? The carbs were very gummy. I cleaned out what I could see.
Paul
Paul
- loudhvx
Re: Resurection of a KZ650
25 Aug 2007 09:28
did you remove all of the jets to clean them and poke them through with a tiny wire etc?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- RetroRiceRocketRider
25 Aug 2007 09:32
Welcome to KZr Paul.
It's likely that you still have a fuel delivery problem.
If you were to hook up a hose to each float bowl drain and loosen the drain screws, do they all flow at the same rate and drain the same amount of fuel?
Did you blow out the carb passages with compressed air when you removed the jets (you did remove the jets for cleaning, right?) to clean everything up?
Are all vacuum and fuel hoses in good condition, and were they re-installed properly (ie: not pinched, and installed on the correct fittings) and securely?
Are the vacuum caps that go on the intake manifold fittings still there, and are they in good shape (ie: snug, and not rock-hard or showing signs of cracking from heat/age)?
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- MNKZ650Guy
25 Aug 2007 10:34
Thanks for the reply. I, too, think it's still fuel. Vacuum caps? Where are these? It does seem like it's not getting enough fuel.
Paul
Paul
25 Aug 2007 10:49
The rubber vacuum caps go on the brass fittings that are on the intake manifolds/carb holders (shown in pic below) which mount the carbs to the engine, and if missing will cause a vacuum leak and make the engine run lean on fuel.
Post edited by: RetroRiceRocketRider, at: 2007/08/25 14:02
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- MNKZ650Guy
25 Aug 2007 14:54
When I pull the carbs, there seems to be enough gas in the bowl but it's not being pulled in. Could that be vacuum? Could those reeds be stuck open. Where does the vacuum come from?
Thanks,
Paul
Thanks,
Paul
25 Aug 2007 18:07
For reference, here's a copy from Kawasaki.com parts diagram of the 79KZ650 carb, together with the parts names listed.
Appears two carb versions were available -- one with pilot screw on the side and another with pilot screw from the bottom. Which version is applicable here?
Regarding source of vacuum (over-simplified), the engine sucks in fuel-air mixture from the carb.
Ref # Part # Description Qty Spec #
1 16005-027
Add to pick list TOP,MIXING CHAMBER 4 4
1 16005-027
4 16019-031
Add to pick list GASKET,CHAMBER TOP 4 4
4 16019-031
5 16003-013
Add to pick list NUT,5MM 4 4
5 16003-013
6 461F0500
Add to pick list WASHER SPRING 5MM 8 8
6 461F0500
7 16039-016
Add to pick list WASHER,PLAIN 4 4
7 16039-016
8 16046-012
Add to pick list SCREW,SLOTTED 4 4
8 16046-012
9 16057-002
Add to pick list SEAT,SPRING 4 4
9 16057-002
10 16040-026
Add to pick list SPRING 4 4
10 16040-026
11 16067-006
Add to pick list BOLT,HEX HEAD,5X14 4 4
11 16067-006
12 39075-1001
Add to pick list LEVER,THROTTLE 4 4
12 39075-1001
13 16033-031
Add to pick list SCREW,PAN HEAD,3X14 8 8
13 16033-031
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-272)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1020)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1022)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1069)
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 0 4
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 4 4
14 39184-1001
15 16008-010
Add to pick list CIRCLIP 4 4
15 16008-010
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-272)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1020)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1022)
16 16009-1013
Add to pick list JET NEEDLE,5CN15 4 (for 16001-1069)
16 16009-1015
Add to pick list JET NEEDLE,5CL10 4 (for 16001-1026)
16 16009-1029
Add to pick list JET NEEDLE,5CL16 0 4
16 16009-1029
Add to pick list JET NEEDLE,5CL16 4
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1020)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1022)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1069)
17 16025-1016
Add to pick list VALVE,THROTTLE,CA2.0 4 (for 16001-1026)
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 0 4
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 4
18 16076-003
18 16076-003
19 16073-014
Add to pick list COLLAR 4 4
19 16073-014
20 16039-015
Add to pick list CAP,STARTER PLUNGER 4 4
20 16039-015
21 16012-015
21 16012-015
22 670B1509
Add to pick list "O" RING,9MM 4 4
22 670B1509
23 16013-008
Add to pick list SPRING,STARTER PLUG 4 4
23 16013-008
24 16016-021
Add to pick list PLUNGER,STARTER 4 4
24 16016-021
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-272)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1020)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1022)
25 16017-1021
Add to pick list NEEDLE JET,0-4 4 (for 16001-1069)
25 16017-1018
Add to pick list NEEDLE JET,AO-7 4 (for 16001-1026)
25 16017-1034
Add to pick list NEEDLE JET,AO-5 0 4
25 16017-1034
Add to pick list NEEDLE JET,AO-5 4
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-272)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1020)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1022)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1069)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1026)
26 49122-1006
Add to pick list PIPE,BLEED 0 4
26 49122-1006
27 16038-016
Add to pick list "0" RING,MAIN JET COV 8 8
27 16038-016
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-272)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1020)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1022)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1069)
28 92063-1029
Add to pick list MAIN JET,#A90R 4 (for 16001-1026)
28 92063-1035
Add to pick list MAIN JET,#A97.5R 0 4
28 92063-1035
Add to pick list MAIN JET,#A97.5R 4
28 92063-1033
Add to pick list MAIN JET,#A100 4 4
28 92063-1033
28 92063-1042
Add to pick list MAIN JET,#A105R 4 4
28 92063-1042
28 92063-073
Add to pick list JET-MAIN NO 107.5R 4 4
28 92063-073
28 92063-068
Add to pick list MAIN JET NO 92.5R 4 4
28 92063-068
28 92063-1031
Add to pick list MAIN JET,#A95 4 4
28 92063-1031
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-272)
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-1026)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-272)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-1026)
31 16038-024
Add to pick list "O" RING 4 (for 16001-272)
31 16038-024
Add to pick list "O" RING 4 (for 16001-1026)
32 16012-022
Add to pick list CAP,LIMTTER 4 (for 16001-1026)
32 11012-1041
Add to pick list CAP,LIMITER 4 (for 16001-1026)
33 16029-004
Add to pick list WASHER FLOAT VLV SEAT 4 4
33 16029-004
34 16030-1001
Add to pick list FLOAT VALVE ASSY 4 4
34 16030-1001
35 92064-1018
Add to pick list PILOT JET,#A15 4 4
35 92064-1018
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-272)
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-1026)
37 16031-031
Add to pick list FLOAT 4 4
37 16031-031
38 16032-003
Add to pick list FLOAT PIN 4 4
38 16032-003
39 11009-1563
Add to pick list GASKET,FLOAT CHAMBER 4 4
39 11009-1563
41 16049-007
Add to pick list SCREW,GUIDE 4 4
41 16049-007
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 0 4
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 4 4
42 16014-1004
42 16014-1004
42 16014-1006
Add to pick list SCREW,AIR ADJUSTING 4 (for 16001-1069)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1020)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1022)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1069)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1020)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1022)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1069)
45 13169-1107
Add to pick list PLATE,JET NEEDLE 0 4
45 13169-1107
Add to pick list PLATE,JET NEEDLE 4 4
45 13169-1107
46 92027-1103
Add to pick list RING,JET NEEDLE 0 4
46 92027-1103
Add to pick list RING,JET NEEDLE 4 4
46 92027-1103
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 0 4
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 4 4
47 92022-1024
48 92081-1072
Add to pick list SPRING,JET NEEDLE 0 4
48 92081-1072
Add to pick list SPRING,JET NEEDLE 4 4
48 92081-1072
Post edited by: Patton, at: 2007/08/25 21:09
1 16005-027
1 16005-027
4 16019-031
4 16019-031
5 16003-013
5 16003-013
6 461F0500
6 461F0500
7 16039-016
7 16039-016
8 16046-012
8 16046-012
9 16057-002
9 16057-002
10 16040-026
10 16040-026
11 16067-006
11 16067-006
12 39075-1001
12 39075-1001
13 16033-031
13 16033-031
14 16007-028
14 16007-028
14 16007-028
14 16007-028
14 39184-1001
14 39184-1001
14 39184-1001
15 16008-010
15 16008-010
16 16009-071
16 16009-071
16 16009-071
16 16009-1013
16 16009-1015
16 16009-1029
16 16009-1029
17 16025-1006
17 16025-1006
17 16025-1006
17 16025-1016
17 16025-1025
17 16025-1025
18 16076-003
18 16076-003
19 16073-014
19 16073-014
20 16039-015
20 16039-015
21 16012-015
21 16012-015
22 670B1509
22 670B1509
23 16013-008
23 16013-008
24 16016-021
24 16016-021
25 16017-096
25 16017-096
25 16017-096
25 16017-1021
25 16017-1018
25 16017-1034
25 16017-1034
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 49122-1006
26 49122-1006
27 16038-016
27 16038-016
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1029
28 92063-1035
28 92063-1035
28 92063-1033
28 92063-1033
28 92063-1042
28 92063-1042
28 92063-073
28 92063-073
28 92063-068
28 92063-068
28 92063-1031
28 92063-1031
29 16022-016
29 16022-016
30 16014-018
30 16014-018
31 16038-024
31 16038-024
32 16012-022
32 11012-1041
33 16029-004
33 16029-004
34 16030-1001
34 16030-1001
35 92064-1018
35 92064-1018
36 92064-1019
36 92064-1019
37 16031-031
37 16031-031
38 16032-003
38 16032-003
39 11009-1563
39 11009-1563
41 16049-007
41 16049-007
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1006
43 16038-022
43 16038-022
43 16038-022
44 16022-007
44 16022-007
44 16022-007
45 13169-1107
45 13169-1107
45 13169-1107
46 92027-1103
46 92027-1103
46 92027-1103
47 92022-1024
47 92022-1024
47 92022-1024
48 92081-1072
48 92081-1072
48 92081-1072
25 Aug 2007 19:06
Am guessing the carb pilot circuits (both air and fuel) are not perfectly "as-new" clean.
Would suggest getting a Factory shop/service manual if available (maybe eBay?) for your specific bike, or at least one of the aftermarket guides such as Chilton, Clymer or Haynes.
Also search the archives on KZRider for tons of KZ650 info on carbs and everything else.
Meanwhile, here's a pretty good general maintenance and repair guide.
Dan's
Good Luck!
Post edited by: Patton, at: 2007/08/25 22:07
Dan's
Good Luck!
