Throttle Issue.... :( :( 1980 KZ750
- Godzpeed
22 Aug 2007 16:50
Repost as i was told not to post in engine...my bad
Well guys I got the Daytona bars thanks to Biquetoast so they should arrive by friday... Anyway I have noticed that after riding the bike for about 20 minutes or so the throttle begins to stick a bit, i mean the actual throttle grip works fine and snaps back properly but the actual throttle will stick and gradually settle down, I dont think this is safe for when I start to ride it specially when changing gears it coul dbe dangerous, anybody know what might be causing this?
- Godzpeed
- wiredgeorge
Re: Throttle Issue.... :( :( 1980 KZ750
23 Aug 2007 11:31
What kind of bike is it? Model?
- wiredgeorge
23 Aug 2007 11:33
- Godzpeed
23 Aug 2007 16:49
ummm...I typed in "1980 KZ750" is that what you need?
- steell
23 Aug 2007 20:23
Godzpeed wrote:
Not really, since there were two different KZ750's made in 1980, a 750 twin and a 750 four (two models of 750 four actually)
So, is it a KZ750G (twin), KZ750E (four) or KZ750H ( LTD four)?
Post edited by: steell, at: 2007/08/23 23:23
- k0pper
25 Aug 2007 11:18
im having a similar problem on my '80 750 LTD. I posted on two other threads of people that have the same problem.
- k0pper
25 Aug 2007 11:28
- Godzpeed
- steell
26 Aug 2007 07:40
First off, is the throttle actually sticking or is the bike just idling at 3k-4k rpm and gradually dropping back to normal idle?
Too high fuel level in the float bowls and vacuum leaks can cause the latter, never seen the former.
