vacuum leak fixed?
- riverroad
- 1980 1000LTD B4
vacuum leak fixed?
19 Aug 2007 13:49
On another post I went through fixing two epoxied spark plug holes, started it up and was greeted by a 3500rpm idle. I removed all the air suction system and plugged all the holes with new caps, ran a piece of hose between the reed valves. The rpms dropped to about 2000 rpms, (idle screw all the way out). Sprayed little squirts of WD-40 around all the carb boots etc., and didn't note any changes in idle anywhere. So then I decided to fix this annoying little fuel leak I've had for a while. It was a pin hole in one of the rubber fuel transfer hoses I believe is fed by the accelerator pump.
Suddenly, the bike idles normally. Is it possible my vacuum leak was because of this tiny little pin hole that dripped maybe one drop of fuel every three minutes?
Or did some other freaky thing happen? I hate it when I fix something and I don't know how. :S
Also, in my Clymers, page 193, it talks about a vacuum sensor. Mine appears to be missing. There is a place for one to be there, but there is no cover or screws there, just the holes. Is this sensor only needed on certain models?
- KZQ
- Administrator
Re: vacuum leak fixed?
19 Aug 2007 21:21
Hi Riverroad,
"Is it possible my vacuum leak was because of this tiny little pin hole that dripped maybe one drop of fuel every three minutes?"
I really doubt that the leak you describe would affect your idle. It's more likely that in repairing the leak you jostled something else and caused it to seal where it had previously been leaking air.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- riverroad
- 1980 1000LTD B4
20 Aug 2007 05:37
Thanks KZCSI, that's what I figured. Dammit. So as far as I'm concerned it's still broke, even though its runnin good. Square one.
And I looked real close around all the carb boots with light and mirror, and they all 'look' brand new.
But number two carb, the one with the accelerator pump bothers me. First, it has that missing vacuum sensor thing. Don't know whether I need it or not. And it has VICE MARKS IN IT! Some clown chucked it up in a vice for some reason, no rag, and beat upon it for some reason. So now I'm wondering if anything is warped in there.
First it's spark plugs JB welded in the f*$^%%# head, now it's hammer time on a carb. WTF!?! What's next? Duct taped shifter forks?? :pinch:
