Starter Jet Removal?
- Ray J
18 Aug 2007 08:27
Is it possible to remove the starter jet? How can you be sure it is clean in there?
Post edited by: Ray J, at: 2007/08/18 11:28
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: Starter Jet Removal?
18 Aug 2007 09:42
I'm not sure about removing it, but what I did was to use some fine fishing line to clear the holes, then I took an air hose attachment that has a long tubular snout, stuck it over the "pole" until it sealed around the base, and blew air through it.
West Linn, OR
- Ray J
18 Aug 2007 10:15
Thanks, Skyman. That is what I did. So I should be set.
