- Thank you received: 3
Will these carbs work?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
From what I understand, stock carbs for my bike are BS34s. I think what I have are VM28s with accelerator pumps. The output ID measures slightly over 28mm. The number stamped on the #1 carb flange is 1098. Current jetting is 105/15.
The PO told me that it recently had the top end redone, and bored out to 1100 CCs. It has a non-stock 4-2 turnout exhaust. Stock airbox.
When I first looked at the bike, we were able to get it running, but it coughed and sputtered quite a lot, and puffed black smoke. But the guy didn't have the airbox mounted. The carb intakes were open to the outside.
So my question is this. I am probably going to try to find some stock BS34s for the bike, but would like to first try to get it running well with the carbs I have. Is there any reason why I shouldn't use these carbs? What would you recommend for jetting?
There are a couple problems with using the VM28s. First, these carbs bump against the petcock, so I'll have to figure something out with that. Plus, I should change to a 2-cable throttle control if I plan to ride it. Like I said, I'll eventually try to get some BS34s, but want to try the 28s as a temporary solution.
West Linn, OR
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- Skyman
Yeah, I also thought about using the Suzuki petcock, especially since I already have one on my B2. I replaced the leaky original with the Suzuki one a few months ago. I can now take the petcock off my M2 and switch with with the Suzuki one on my B2. Now my B2 will have the OEM one again.
Thanks also for the advice about using the 650 CSR throttle assembly. In looking up the part number, it looks like that exact same assembly was used on 550s and 750s too. So I should be able to find one.
Now I just need to figure out the proper jetting on my VM28s. Hopefully someone here (WG?) can opine on that subject.
Edited to add: I just saw the thread about WG being gone for a while. I hope all is okay with him.
Post edited by: Skyman, at: 2007/08/17 23:30
West Linn, OR
- The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Skyman
And on the throttle drum, there is only one slot for the cable nub.
West Linn, OR
- Skyman
West Linn, OR
- The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Skyman
The Suzuki's use a different setup for the choke it is actuated with a cable instead of a knob on the Kawis. They could be made to work but it will take some dicking around to make them work. You would be better off getting a set from a Kaw they shouldn't be too hard to find. I just picked up a like new set at Mid-Ohio for $20.00:) that I plan on using on a 750 GPZ engine I have.
What is "Mid-Ohio"? Is it a store? A swap meet? Or just the geographical location where you found it? :lol:
Man, if I could find a set anywhere close to $20, I'd be very happy. I've seen a few on Ebay recently go from $130-$250. :pinch:
West Linn, OR
- Skyman
From the photos, looks like someone painted the carbs black.
Will carb dip (like that NAPA stuff) take paint off?
Post edited by: Skyman, at: 2007/08/20 11:53
West Linn, OR
- The Gringo
As to the carbs you just bought, the Spectre models came painted black from the factory. The seller is probably right the jetting should be real close for what you have. I don't know that I'd screw with trying to remove the factory paint from them, as I understand it it is a real beach to get it off. Unless you are trying to do a 100 point restoration I'd leave them as is JMHO.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Skyman
I wondered about it being factory paint. Seems that every set of carbs I've seen from the Spectre is black. I guess I don't mind having black carbs if the paint is in good shape. We'll see what they look like when they arrive.
West Linn, OR
- Skyman
Thanks.
West Linn, OR
