adjustemmet carburettor ...
- scaf
12 Aug 2007 13:12
Salute !
my engine become very hot just after few Km indifferent by speed
I speak with my frends and they say it is from carburettors have too less gas or too much air ...
can you tell me how carburettor must be adjustment ? it is necessarily an special tools for this ?
ps i check avance ,is ok ,,, wires ,,, etc
o and don't forget ...make sometime smoke (grey smoke)
tnx
Post edited by: scaf, at: 2007/08/12 16:12
tnx
- arobsum
Re: adjustemmet carburettor ...
12 Aug 2007 20:24
yes. running lean. check your fuel level in the carb. bowls.
- scaf
12 Aug 2007 22:08
yes ... but how must to look the level from carburretors ? , I mean.... how I'm sure the level is ok ?
tnx
tnx
- Makarth
12 Aug 2007 22:29
check the carb bowl level by hooking a clear tube to the orifice at the bottom of the carb and bleed the gas out. then hold the tube up to the carb (vertically) and see where the gas tops out on the tube it should be about .5-1.0 cm to the top of the bowl if my memory serves me correctly. I had this issue with my petcock being clogged a while ago
- JMKZHI
Last edit: 03 Dec 2008 09:57 by JMKZHI.
