running but not well
- bubba_d
11 Aug 2007 22:31
had posted recent problems with fuel mileage. theres more to it. im only getting 15 miles per gallon. bike will backfire if i let off the throttle at 4k or more. idles fine. at highway speeds 55 plus she doesnt do so well. keep in mind i am 235lbs. in 4th and 5th gear i cant gain speed unless im going downhill. if i open up to full throttle in 4th or 5th it seems to bog down. if i ease into it exremely slow it does ok on flat ground or downhill. i can achieve high rpms in 1 2 and 3 but 4 and 5, 4k is the best. any advice would help. thanks
1977 kz1000.
- bubba_d
Re: running but not well
11 Aug 2007 22:33
recently cleaned carbs blindly. never touched a set of carbs before. runs better than it did before though.
1977 kz1000.
- adri4n
12 Aug 2007 10:49
has the bike been tuned lately? I'm not an expert, just started getting into working on bikes, but it sounds like the timing might be out on the bike, that sounds like the same problem I had with my bike before I managed to get it properly in tune.
- Nelson
15 Aug 2007 13:48
have u checked the usual stuff?
clean air filter,
clean plugs,
timing,
points if ya got em,
clean fuel tank,
valve clearance
clean air filter,
clean plugs,
timing,
clean fuel tank,
valve clearance
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- BSKZ650
16 Aug 2007 13:56
I think a full tune up is in order, also checking the compression and valves, and advancer in addition to things already said.
also what gear is on the bike, wonder if someone has changed it out
77 ltd1000, current rider
76 kz900, just waiting
- bubba_d
18 Aug 2007 18:56
pretty confident that the bike is bone stock except for the superbike bars that i put on today.
1977 kz1000.
