What Carbs
  • HOGEATER
  • HOGEATER's Avatar Topic Author
  • Been riding 2 wheels since 1965,
What Carbs
11 Aug 2007 15:45
#163239
I have a 78 KZ1000 LTD but can't find kits for the carbs. The engine # is KZT00AE077366 and the Frame # is KZT00B-521775. I ordered kits for the 77/78 a1/a2 LTD and they don't fit .
The carbs have a 1.180 throat on head side and a 1.580 throat on filter side, no overflow tube on the bowls but have a 17MM plug that can be removed to drain also have a screen filter attached to the needle seat. They are MIKUNI,s but what size???? PLS HELP
HOGEATER(CHUCK)
  • arobsum
  • arobsum's Avatar
Re: What Carbs
11 Aug 2007 15:56
#163243
17mm plugs came on the very early vm28's and the often sought after vm29's. what do the tops of the carbs look like? lid held on with 2 screws or 3?
  • HOGEATER
Re: What Carbs
11 Aug 2007 16:10
#163246
The tops have three screws , 1 in the front of the cover and 2 in the back. Do you know who sells kits for these ???
  • PLUMMEN
  • PLUMMEN's Avatar
Re: What Carbs
11 Aug 2007 16:17
#163252
try z1 enterprises in links sectionB)
  • arobsum
  • arobsum's Avatar
Re: What Carbs
11 Aug 2007 17:04
#163259
sounds like you have the vm29. whatever you do, hang on to them! they are quite expensive on ebay.
  • HOGEATER
Re: What Carbs
11 Aug 2007 17:24
#163263
I just want to get some kits for them so I can get this monster running and do some playing with it....
HOGEATER(CHUCK)
  • arobsum
  • arobsum's Avatar
Re: What Carbs
11 Aug 2007 18:00
#163266
HOGEATER(CHUCK)
Z1 enterprises.com
  • brianrae33
  • brianrae33's Avatar
Re: What Carbs
13 Aug 2007 06:50
#163510
check around the circumferance of the intakees..if they have lots of brass fittings around there they are 29's..
1982 kz1000ltd
  • HOGEATER
Re: What Carbs
13 Aug 2007 12:53
#163563
no brass fittings , but the needle valves have small filters on them. I measured the throats , the front is 29.62approx MM and the rear is 39.80.
send your email addy to me and I'll send some pics of them I tried here and they are too big.
some of the guys on the other KAW site they thought these carbs were from early Z1..
Thanks
Chuck
email chuckschoppers@yahoo.com
Post edited by: HOGEATER, at: 2007/08/13 15:56
Post edited by: HOGEATER, at: 2007/08/13 15:57
Post edited by: HOGEATER, at: 2007/08/13 16:38
  • wiredgeorge
  • wiredgeorge's Avatar
Re: What Carbs
13 Aug 2007 13:41
#163575
You have Mikuni VM29 smoothbores. On the flange (under the choke lever arm) is an ID mark stamped on the carb flange... most have 29 xx such as 29 14 ID mark.
  • HOGEATER
Re: What Carbs
13 Aug 2007 13:59
#163599
Thank you ,
I just looked at Z1 carb ID,s and definately match the 29s .. Thanks again
Chuck
