kz650 carb issue
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
kz650 carb issue
11 Aug 2007 07:54
Hi people!Im currently putting together a 77 650.Ive picked up 3 of these bikes for parts to build one.I am working on the carbs and I have one set that is from a 77 and another set from a 79,I believe.The newer set has a fuel pump the older has none!Are the bowls and parts interchangable?If so do i want to use the set that has air screws for adjustment or the one with no adjustment.I dont want the fuel pump Right???Any advice would be greatly appreciated!!!Thanx
Post edited by: BoZ650, at: 2007/08/11 14:28
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- Bluemeanie
Re: kz650 carb issue
11 Aug 2007 12:22
What you are refering to is the accelerator pump. Mine has one. Mine has "air" screws on the top/side and the older ones have "pilot" screws. I could be wrong but I believe the bowels, caps are interchangable. I think most internals are too (jets,etc) Someone will pipe in and corect me if I'm wrong.
- BoZ650
11 Aug 2007 12:46
thanks for the info!any suggestions on to run the accell.pump or not?
- bubba_d
11 Aug 2007 22:16
i recently bought my bike and have the mikuni round slides with the accelerator pump. cleaned them and they seem to work ok. dont have anything to compare to besides when they didnt work at all.
1977 kz1000.
- The Gringo
- ¡Usted no necesita otra motocicleta!
12 Aug 2007 04:16
I've got a 77 650 C-1 and have basically done the same thing you are thinking about. When I first got the bike the carbs were all gummed up from sitting for 15 years with old gas in them:sick: :sick: . I had a set of clean pumper carbs I had just picked up off Ebay so I put them on in order to get the bike running, well it ran, but it ran like sheite. Over the winter I cleaned up the original set and the bike likes them much better.
Remember the 77's were pre emissions bikes so the factory could just set them up where they ran the best. The pumper carbs were a band-aid so they could meet emmissions and still have some form of driveability. My advice would be to use the older carbs if at all possible.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
