fuel isnt making it to the carbs
- SebRain77
- When in doubt, gas it!
10 Aug 2007 03:09
cleaned the tank last night. re insstalled it, to see if the thing would start. nothing. emptied the carb bowls, stale fuel in them. put back everthing together. put new fuel in. first question. when the fuel comes out the petcock, should it drip, or flow out? second question. if the needles in the carbs are clogged, could it be why the bowls are staying empty and the fuel is not making it all the way to the engine? I'm no mechanic, I'll need all the advice I can get to prove to the wife that this 800 dollar purchase wasn't a waste! Thanks people!
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
- Night_Train01
Re: fuel isnt making it to the carbs
10 Aug 2007 04:27
The gas should flow out of the petcock. Make sure there is not a fuel filter in the line that has clogged up.
- wiredgeorge
10 Aug 2007 04:28
A 77 KZ650 should have a gravity feed petcock? If so, then put the petcock in the OFF position, remove the gas hose from the petcock and momentarily turn the tap to the ON position. Gas should flow in a steady stream. If it doesn't... you didn't give any clear detail but you mentioned drip... if it drips, the petcock is the fault and needs to be removed and cleaned and likely rebuilt. At this point, I would be considering replacement. When you remove it, keep in mind there are filtering screens on both fuel pipes inside the tank and these must be unobstructed.
- outatimeoutlaw
10 Aug 2007 16:56
Some kz's like mine came with an automatic fuel valve.
These require a suction hose from the carbs. you can tell them apart by looking for two connections.
One is to the carbs,the other is the suction hose.
You can buy the kit to fix it from dennis kirk or kz ent online. I'm thinking Your bike might have a different tank on it.Also if it has this type of valve,it will have a position that says PRIME and gas will flow in this position,so you can ride like that,or as GEORGE said it's just clogged up. If the carbs are screwed up, send em to WIREDGEORGE as he is an expert in that field.
- SebRain77
10 Aug 2007 17:49
Thanks, I'll remove it, and try to clean it the best I can. Something's gotta be obstructing the flow. And then I'll go from there. I'll let you guys know what's going on
- SebRain77
11 Aug 2007 14:38
Alright, how about this. The bike has been sitting around for 7 years in a garage, less than a quarter tank of fuel in it. And no fuel stabilizer. How nice! You guys think everything is clogged up? I think I should take the whole thing down, piece by piece, and clean everything; clean or replace petcock, change fuel lines and filter, dismantle the carbs and make them soak in carb cleaner for half hour or so each, but one at a time! I'm not about to say "Hmmm, look at that, spare parts!"
- HOGEATER
- Been riding 2 wheels since 1965,
11 Aug 2007 16:45
If it has sit that long ,yes I'd drain everything and clean the carbs. When gas sits for along time it evaporates and leaves nasty varnish gunk on everything.
Let the carbs soak for a couple of days then clean them up all pasages have to be cleaned.
HOGEATER(CHUCK)
HOGEATER(CHUCK)
- SebRain77
06 Sep 2007 14:46
disassembled the petcock, changed in-line fuel filter as well as fuel line, disassembled the carbs, cleaned everything, now the thing starts! But, I guess since I disassembled the carbs I fucked up the fuel air mixture.... I just need to find a shop that will adjust them. Next step will be a safety, then.... riding time!
06 Sep 2007 15:47
SebRain77 wrote:
Famous last words, need to find a shop that will adjust them.
And when that fails, send them to wiredgeorge.
wg rules!
wg rules!
- SebRain77
07 Sep 2007 04:20
Yeah I know! I'm still thinking about it, but WG is a loooong way from where I am! I'm just wondering how much that would take... I'm kinda anxious to ride it!
- Mcdroid
- Gone Kwackers
07 Sep 2007 04:49
SebRain77 wrote:
Unless you really, really luck out with a local shop, comments you might get will include:
1)bring the bike in, I've never seen one before
2)wow, your bike is older than my mechanic!
3)what can be so tough about working on carbs?
4)good luck, parts aren't available any more
Contact 'wiredgeorge' for a time estimate...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- tjettim
07 Sep 2007 06:21
Just turn all the screws all the way in and
then back them out 1 1/2 turns.The should at
least idle now even if you have to turn the
idle screw in on the throttle linkage.If you
adjust any screw do all four carbs the same
amount.If the engine speeds up,you went the
right way.If not, try the same amount in the
oposite direction.After finding where the engine
seems to idle the fastest and the smoothest,
(take notes as you make your adjustments)
adjust your idle screw back down to around
1100 rpm.If you have to set it much higher than
1100rpm to get a smooth idle,the carbs probably
need syncronizing.
need syncronizing.
