Put wideband O2 sensor on bike tonight. Interesting..
- kxhonda
This tells me that I need to drop my pilot jets down a size. The wierd thing is that I still have the stock 115's in there. And this is with pod filters and kz750 cams. Seems to me that I would need to go up a size on the pilots not down. Anyone know why this is?
1977 Kz650B1 #576th made.
Warsaw, In
- gpzrox
I never did really figure out the reason, but it really woke the machine up.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- newbikekiller
Did you retain your 650 head?
My engine (700cc piston/jugs 750cams pods/4-1) was installed on a 650 head and jetted for that first,
I found that the pilot jet was 1 size too small and the needle jet needed to be opened up to the maximum richness too.
How did you install that sensor? Sounds very useful especially in critical areas in 2-stroke tuning.
If I could instantly now how lean/how rich my motors were running that would be a big deal.
Thanks!
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kxhonda
Wideband is a Tech Edge buget unit from, wbo2.com/ . I ended up building the DIY one to save some cash.
Post edited by: kxhonda, at: 2007/08/15 11:12
Warsaw, In
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
are u out a 1/4 turn from seated?if so that woud be an indication that the pilot is too small.general rule would be less than 1 turn could stand to go down a size.those 02's are $$$$.how did u make ur's?how much $$?
Less than $50 for the wideband O2 sensor from Amazon.com, and the wideband controller is $70 in kit form and $90 assembled (with display) from www.14point7.com/JAW/JAW.htm
Is that cheap enough?
Post edited by: steell, at: 2007/08/19 11:58
- loudhvx
- Thank you received: 1616
Is that cheap enough?<br><br>Post edited by: steell, at: 2007/08/19 11:58
I'm considering the kit with the display, but still have a few details to learn.
How much current does the whole thing use? I read somewhere the sensor's heater can use up to 10 amps.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- steell
I think the controller with display uses 1 amp or less.
Here is a link to the thread on the MS board discussing it (the JAW controller).
www.msefi.com/viewtopic.php?t=26503
Post edited by: steell, at: 2007/08/20 15:00
