I need float height for 1984 ZN700
- ten6
08 Aug 2007 17:59
Hey guys, I need the float height spec for 1984 ZN700 with Kehin Carbs. I need to know is it 18mm +/- or is it 21mm +/-
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- RetroRiceRocketRider
Re: I need float height for 1984 ZN700
08 Aug 2007 18:55
The specs from the FSM for the '84 ZN700 show the "Service fuel level" as 0.5 +/- 1 mm, and is the measured level the fuel sits below the bottom of the carb where the float bowl attaches at.
If you need any more ZN700 specs just let me know, I recently scored a FSM in great condition for a song off of eBay.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- ten6
08 Aug 2007 18:59
I have that FSM but I need the other measurment because I don't have the little tube setup to measure the Service level.
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
08 Aug 2007 19:17
Ok, I see what through you for a loopp in the FSM.
Being that the ZN models are listed as a supplement in the back, the rest of the manual that covers the KZ750N (Spectre) and Z750P does cover some of the ZN's specs and what-not.
If you look on page 1-10, it shows that although the KZ750N (Spectre) has a diff fuel service level, it has exactely the same carbs, Kehein CV34's, as the ZN's. The Z750P used Mikuni BS34 carbs.
And on page 3-3 it shows the float height specs for both the KZ750N and Z750P models, and in brackets it shows which carbs each uses.
So to make a long story short, Float Height for the ZN700 is 21 mm.
Post edited by: RetroRiceRocketRider, at: 2007/08/08 22:19
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- ten6
08 Aug 2007 20:54
Cool, thanks for the info. It was a big help. I was having a real bad day before this...this helps smooth out a few rough edges...
Well, this and a few beers...
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
