kz1000 g injector flow rates
- kz1000g megasquirting
- I chrome plate smaller items, pm for info.
05 Aug 2007 11:59
Hey guys,
Does anyone know the flow rate of the stock injectors? I thought came across someone stating them as being 180 cc/min once, but not positive.
Thanks!
Thanks!
- steell
Re: kz1000 g injector flow rates
05 Aug 2007 12:15Flow Rate (36psi/100%): 180-200cc/min, 2,5Ω
Per www.msefi.com/viewtopic.php?t=6627
And congratulations on doing it right, instead of reverting to antique carbs
Post edited by: steell, at: 2007/08/05 15:17
- Lorcan
- Speed Loony
06 Aug 2007 13:00
That would be about right, the turbo injectors are about 230cc/min, the GPz1100 ones are known to be less than that, probably 200-210cc so I would expect the earlier 1000cc models to be less again and around 180cc given the power output. I've had good luck with RC injectors if you are looking for replacements. Bear in mind though that pretty much everyone nowadays rates injectors at 3 bar pressure (43.5 psi) and Kawasaki used 36-37psi for all the early fuel injected bikes, so allow for the difference when you go shopping
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
