What are these?
  • donthekawguy
  • donthekawguy's Avatar Topic Author
What are these?
04 Aug 2007 14:59
#161730
I got these off ebay last year and the guy said they are 34's. I pulled them out of the box today and found they froze up and smell horrible.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • JR
  • JR's Avatar
Re: What are these?
04 Aug 2007 15:58
#161745
The measurement would be spot on for 34mm (34mm = 1.338 inches)but they look different from my Keihin CV34s. The choke linkage is different and that fin thingy on the top of 2 or 3 has me puzzled so I'll take a guess and say Mikuni BS34.
Lets see what the experts say :)
  • donthekawguy
Re: What are these?
04 Aug 2007 16:02
#161746
They are Mikuni's. Looked like 34's to me also just checking to make sure. The throttle won't move at all so I guees they go to WG for a rebuild. I just looked up his site and found complete instructions for install. SWEET!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • wiredgeorge
  • wiredgeorge's Avatar
Re: What are these?
06 Aug 2007 08:39
#162037
I am going to trust JR and if they ARE 34mm, they came off a GS1000 or GS1100. That means that the spacing is correct for your bike. If JR can't do inch to mm any better than me, they will be BS32 carbs off either a GS750 or GS850. Unfortunately, those bikes used angled carb holders and carb spacing is different (inside two carbs are too close). You can stuff them in BS34 carb holders but the carb holders will soon fail. That cable holding bracket is for the choke cable. You will need to figure out how to mount a remote choke to pull that bracket to open the choke plungers. It is pretty hard to modify those carbs to accept a Kaw style pull choke rod. You have to do some precision drilling which I am not equipped to do. Also keep in mind that you will not be sync-ing those carbs. No vacuum ports except on the one carb to provide vacuum for a petcock. Some tech issues to overcome I guess if you want to use them.
  • JR
  • JR's Avatar
Re: What are these?
06 Aug 2007 10:50
#162053
wiredgeorge wrote:
If JR can't do inch to mm any better than me............
I used this website for conversion
www.convertunits.com/from/mm/to/inches
From Don's pic the measurement looks like 1 & 11/32 inches which would work out at 1.34 inches.. close enough to the web conversion of 34 mm = 1.338 inches ?
Hope they fit don
Post edited by: JR, at: 2007/08/06 13:51
