CV carbs?
  • seanof30306
  • seanof30306's Avatar Topic Author
CV carbs?
03 Aug 2007 12:30
#161577
These are supposed to be from an '82 CSR KZ 650. Are they the constant velocity carbs I keep hearing about?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • seanof30306
Re: CV carbs?
03 Aug 2007 12:31
#161578
another one
Post edited by: seanof30306, at: 2007/08/03 15:32
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • mariozappa
  • mariozappa's Avatar
Re: CV carbs?
03 Aug 2007 12:33
#161579
yes
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • seanof30306
Re: CV carbs?
03 Aug 2007 12:34
#161580
try again
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • seanof30306
Re: CV carbs?
03 Aug 2007 12:36
#161581
mariozappa wrote:
yes
Mario,
I see you have an '82 KZ750. Does it have the CV carbs? If so, does it get better fuel econimy that your other, earlier KZs?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • mariozappa
Re: CV carbs?
03 Aug 2007 12:42
#161582
I haven't really noticed any difference in fuel economy, but they're a bitch to tune!
1977 KZ650C1
  • wiredgeorge
  • wiredgeorge's Avatar
Re: CV carbs?
03 Aug 2007 16:53
#161616
The BS32 and BS34 look pretty much the same and I couldn't tell you if the carburetors you show in the pics are 32mm or 34. The 650 came with the BS32 carburetors. To figure this out, you will need to measure the inside diameter of the engine side venturi.
