Kz 750 with K&N air filters
- puch175
01 Aug 2007 00:02
Hello,
my name is Marko, Iam from Slovenia (Europe), (excuse me about my bad english).
First of all, this forum is the best way to find out more about Kz motocycles, just keep on.
And now about my problem.
I own Kz 750 l.81, E-model, 4 cylinder with keihen carbs. But now I have put on 4 into 1 muffler and 4 K&N air filters type RC-2580.
And now it does not work well, what shall I do, drill prim. and secon. jet (see attachment), or what, please help me.
Thank you in advance,
Marko
Marko
- almarconi
Re: Kz 750 with K&N air filters
01 Aug 2007 02:10
Hey Marko,
What you need to get is a dynojet stage 3 kit for your bike. It will have the necessary jets so you can get your bike tuned. Their part is #2102 fit 80-83 KZ750 with keihen carbs. The addition of pods(more air) caused the bike to run lean. Since you are in Europe you will probably want to go to this site
www.dynojet.co.uk/jetkits/index.htm
Good luck with your project.
Al
Al
1981 KZ550C LTD (SOLD)
1980 GS750L
1982 KZ750N1 Spectre (New Project)
1980 GS750L
- wiredgeorge
01 Aug 2007 04:28
I am not a fan of aftermarket jet kits for KZs... all of them have a "one-size-fits-all" jet needle and a set of main jets. The rejet of the Keihin 750 carbs depends on which jet needle/main jet combo is used in the bike. There are two versions of the carburetor versions are easiest by noting the badge number on the jet needle. The needle jet, the jet that fits up in the bottom of the venturi that the needle jet fits in is much larger diameter in one version rather than the other and uses a smaller main jet when rejetted. You will find that these rejet solutions will work far more effectively than any jet kit and these solutions will be far less expensive as well. If you can't find larger "main jets" just try the larger secondary mains... Here are my specs and recommended rejet for pods/pipes:
CV34 and jetting
The CV34 comes in two varieties:
CV34 #1 OEM Jetting
Secondary main #125
Main #62
Jet needle N01A
Needle jet smaller opening (no badge)
Pilot #35 (pilot well plugged)
To rejet for pods/pipes #140 #70
CV34 #2 OEM Jetting
Secondary main #92
Main #68
Jet needle N100
Needle jet larger opening (no badge)
To rejet for pods/pipes #130 - rest stock jets
CV34 and jetting
CV34 #1 OEM Jetting
Secondary main #125
Main #62
Jet needle N01A
CV34 #2 OEM Jetting
Secondary main #92
Main #68
Jet needle N100
- JR
01 Aug 2007 07:25
Hi Marko
This is what I did. See picture.
I dont know where you would find jets in Europe but if you have problem you could try here
www.z1enterprises.com/
just type "keihin" in the search bar.
ood luck
ood luck
- djcody
02 Aug 2007 20:12
Same problem here but I had a great temporary fix to that. With the airpods you get more air than with the box so yes you need to rejet but until you get the new jets you can go to walmart or somewhere and buy 4 sweat wristbands and put over the airpods. I got the color to match my bike so it looks alright. Place them all the way on the pods even covering the clamps and leave a little over 1/2 inch off pod showing in the back and it will purr like a kitten on the freeway with no problems.Even on the windiest of days.
77 KZ650C airpods and 4 into 2 turn outs exhaust. VM carbs
82 550 LTD all stock except air pods
