starter plunger stuck
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
25 Jul 2007 13:45
#159578
i dont really know how to describe this but here it goes anyway, i have a 1976 kz 400d,i cleaned the carbs out, but now it seems like the starter plunger iin the 1st carburator is froze in one place. Anybody have and sugestions on how to free it up
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • galaxian
  • galaxian's Avatar
Re: starter plunger stuck
25 Jul 2007 13:58
#159584
Do you mean the slide. The cylindrical part that goes up and down and has the needle through it?? Sounds like no matter what you need to remove the carbs and in that case post a pic of the part in question.
1977 KZ1000A1, 1979 KZ650 C3
  • oldkaws4ever
25 Jul 2007 14:06
#159589
no, the starter plunger which connects to the choke assembly
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Bob_79KZ
  • Bob_79KZ's Avatar
25 Jul 2007 21:06
#159712
Well it worked BEFORE you rebuilt the carbs, right?
So it sounds like you may have assembled it wrong. Did you put the forked thing between the two washers on the plunger?
Sounds like its time to do it over:P
I'm not being a smart-a$$...I can't think of any other reason for the problem.
Bob
Post edited by: Bob_79KZ, at: 2007/07/26 00:16
  • oldkaws4ever
25 Jul 2007 22:20
#159724
the bike has been parked the better part of 2 years. I didn't really check if it was stuck, the carbs have been apart for a couple weeks. See the weird thing is that the other side works perfectly
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • wiredgeorge
  • wiredgeorge's Avatar
26 Jul 2007 05:38
#159764
There was gas in the well that the plunger sits in or perhaps some moisture. I can't remember exactly how the plunger on the little Keihin carb is assembled but take off the plastic thing that the actuating arm picks up... probably a small circlip holding the plastic on. Then squirt some PB Blaster or Kroil into the hole where the plunger is stuck and let it sit a bit. Then take some vise grips and put on the plunger arm (TRY NOT TO SCORE UP THE METAL!!!) and twist the plunger working it back and forth to break the goo that is holding it. Once you can work the plunger back and forth, you will be able to pull it out. You may have to remove the actuating arm to get it out... I would remove it and clean it good and clean out the well with spray carb cleaner... there is a hole in the bottom of the well... make sure gas can get through that hole using the spray cleaner because it will likely be plugged and that is where gas gets picked up for the choke (enrichener) circuit.
  • galaxian
  • galaxian's Avatar
26 Jul 2007 06:29
#159779
i didnt realize the choke was called that. You live and you learn.;)
  • galaxian
  • galaxian's Avatar
26 Jul 2007 06:30
#159780
  • wiredgeorge
26 Jul 2007 06:39
#159784
The choke lever on that carb says choke but the function is to enrichen the start up circuit... on other types of carbs, there is a butterfly or flap that closes off the intake venturi, like on a car carburetor and these are actual chokes... the shut off airflow causes the starting mixture to be richer. This type system is used on the CV34 and and other Keihin CV and CVK carbs. When a plunger is used, like on these Keihin carbs (CVB36 I think), or most Mikunis, the circuit actually enrichens and doesn't choke but all of them will say choke on the knob or lever.
  • oldkaws4ever
26 Jul 2007 22:20
#159992
well i sprayed some pb blaster in it, now im going to let it set all night and into tommorow. I hope this works. I really wanna hear my baby pur again
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
