Replacing Petcock
  • Ray J
  • Ray J's Avatar Topic Author
Replacing Petcock
22 Jul 2007 15:19
#158709
I need to replace my Double Outlet Petcock. On Z1enterprises, they only have a single outlet:
Petcock - Custom Chrome - Single Outlet 22mm thread nut - Left Side Spigot
TU48-9716
Engineered and designed to eliminate all internal O-rings. The innercore design insures against gas leakage while providing maximum flow. Features a filter screen, reserve setting, and chrome body. Left Side facing output nipple
$23.99
Can I use this and put a "T" in the line? The only double outlet petcock they have is $85.
  • anarki650
  • anarki650's Avatar
Re: Replacing Petcock
22 Jul 2007 16:56
#158729
I wouldn't think that the single outlet would allow enough fuel flow to accommodate the stock double outlet requirement. I could be wrong of course, but that's what I'd think.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • BSKZ650
  • BSKZ650's Avatar
22 Jul 2007 17:39
#158734
it will flow enough, the fuel line should be 1/4 inch just make sure you have a filter in line
77 ltd1000, current rider
76 kz900, just waiting
  • Ray J
22 Jul 2007 18:49
#158751
Thanks, 650. I thought the double outlet was a bit of overkill, since I am not track racing. I always thought the two discs on the front wheel was overkill too, but it looks good.
  • wiredgeorge
  • wiredgeorge's Avatar
23 Jul 2007 11:21
#158920
I have a KZ900 carb test bike. I use a Pingel adapter plate and Drag Specialties petcock and it will flow enough gas to keep ANY carburetor busy (use 1/4 fuel line). I test BS34 and VM33 carbs regularly and have NO flow problem. The Drag Specialties petcock is the less expensive one (about $20) with a single outlet that Z1enterprises.com sells. A Pingel might even flow more; they claim to be "high flow" petcocks. Use a white vacuum fitting tee from the autoparts store to split the line and use an inline fuel filter between the petcock and split.
