kz 750 carb....im new at this
- higechops
please help
aaron
- John T
- Thank you received: 2
stock exhaust?
True Wisdom Only Comes From Pain.
- anarki650
- Thank you received: 5
For my 650 with pods and a slightly more free flowing exhaust I'm running the stock 15 pilot jets and have upped my mains to 115s (although I'm thinking that 112.5s would be a better match). But still, the mains are several sizes over stock jetting.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- JR
- Thank you received: 449
You need either a 140 and a 70 jet as per wiredgeorge or a 137 and 62 as I did.
Call Z1 Enterprises for the jets. Dont throw out that original airbox just yet....just in case you have problems finding the smaller jet.
Post edited by: JR, at: 2007/07/22 20:44
- higechops
- Snakebyte
Is it a 750 twin or 4? From all my experience with airbox to pods you have to rejet to allow more fuel. Of course, I've only ever worked on the mikuni vm24 carbs on the kz650s. Not sure about CV type carbs, but I would imagine that they'd need rejetted the same.
I have a 650-4 with pods and freeeee flow exhaust, meaning no insulation just a metal baffle at the end for coppers:evil: . I have 15 pilots 110 mains. I'm thinking of takeing wiredgeorge advise and throughing the 17.5 back in due to I never adjusted the air bleed with the 17.5 so it ran rich at idle, but man did it respond hot and cold, and cold staart was a breeze.it ran good just smoked a lot. So I put back in the 15 pilots.
- Snakebyte
- wiredgeorge
- ronjones
it is a 1978 kz 750b twin and it has the stock exhaust
HI higechops, I don't have the B but you might want to check out this link. www.armbell.com/kz400/viewtopic.php?t=43...start=0&mforum=kz400
Also this one,
www.armbell.com/kz400/viewtopic.php?t=363&mforum=kz400
they might give you a starting place.
Good luck
Ron
Post edited by: ronjones, at: 2007/07/24 16:27
- John T
Sorry to get off topic, but ...The problem with sticking pods on the 750 is that the big BS series carbs contain little tiny main jets that are screwed into the float bowls.
George,
How common is it that the Jets get stuck in the bowls?
On my carbs, someone must have buggered the top of the jet with an improper screwdriver size or something...
But I figure, I'll keep the airbox, the jets will never have to come out..
Also, where can I buy new floats for BS carbs?
my brass floats are leaking like the titanic..
:dry:
- wiredgeorge
- John T
