Fuel fitting
  • mjhworth
  • mjhworth's Avatar Topic Author
Fuel fitting
21 Jul 2007 00:25
#158394
Help! I am looking for part number 92005-1026. It is a fuel fitting for a 1980 KZ750 E1 (and others)that has been discontinued by Kawasaki. Mine is cracked and I need another.:(
  • JR
  • JR's Avatar
Re: Fuel fitting
21 Jul 2007 13:06
#158463
It's that fuel inlet T junction between carbs 2 & 3 that swivels. Mine was leaking around where it enters each carb and I dried it off and put JB weld around it....2 years ago and no leaks since.
Sorry but I cant suggest where you might get the part. Can only suggest repair. JB Weld is good for gas leaks but you have to dry the piece and let the stuff cure for 24 hours before using.
  • Skyman
  • Skyman's Avatar
Re: Fuel fitting
21 Jul 2007 14:30
#158476
West Linn, OR
  • mjhworth
Re: Fuel fitting
21 Jul 2007 16:57
#158498
This is the "T" fitting. Not sure if JB Weld would work... the plastic is cracked and actually is loose enough to rotate around the aluminum tube.
  • mjhworth
Re: Fuel fitting
21 Jul 2007 17:00
#158499
This fitting, at Z1, might work... if all else fails, I will order it and give it a shot.
thanks
