stuck jet
- skitch
stuck jet
02 Jan 2006 14:30
I have been trying to rebuild my Mikuni carb; nothing goes smoothly. There is a small jet that won't come out. It's down inside, and seems to be corroded. Any suggestions?
- wiredgeorge
Re: stuck jet
03 Jan 2006 06:40
Perhaps described which carburetor and which jet would help. Removing stuck jets is an iffy process at best and there is NO general tips I can give. I can probably give you specific tips based on which carb and jet (hopefully).
- skitch
Re: stuck jet
04 Jan 2006 20:32
Mikuni BS34
I tried unscrewing it, and sheared off the end. I ended up dilling and retapping the hole. So, the new jet is in there. We'll see how much I messed up this spring.
