syncing carbs
- mark1122
- Keep twisting it
syncing carbs
13 Jul 2007 13:45
i have 33mm smoothbores.my carb boots do not have syc spigots.How can i sync these? are there other boots available?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wiredgeorge
Re: syncing carbs
14 Jul 2007 08:27
No vacuum ports ON the VM33 so you are forced to bench sync only or fab a set of carb holders... pluck the vacuum ports from another set of carb holders and install in the 33 carb holders by drilling a hole and gluing them in.
- mark1122
- Keep twisting it
Re: syncing carbs
14 Jul 2007 13:06
as i understand it the syncing only helps at idle and doesnt do much after that.is that true or is there more to it?is bench syncing sufficiant?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wiredgeorge
Re: syncing carbs
15 Jul 2007 08:38
It depends on how far off vacuum is... it will cause the bike to run poorly at all rpms if bench sync isn't done properly... if you can do it properly, it should get you close enough where it doesn't affect things up top. You need to be able to bench sync pretty well to get the carbs within spec.
- mark1122
- Keep twisting it
Re: syncing carbs
15 Jul 2007 08:51
Thanks George ,i will double chech next time i have them off(soon).
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
