Carb help please !
- Robu
Carb help please !
13 Jul 2007 08:41
I have searched thru the older post and still confused
My KZ650B2 has stock airbox and last year installed a Kerker 4 into 1 my carbs are running terrible this year and need cleaning Im thinking since I will have them apart may as well re jet in order to run smoother when I changed the stock exhaust it ran okay with a slight hesitation and harder starting when cold is their any rule of thumb I can use to help my situation? This Old guy would be very appreciative with any help you can give me. Thanks Rob
- wiredgeorge
Re: Carb help please !
14 Jul 2007 08:53
The cleaning will do more good than rejetting. If you have a 4 into 1, shouldn't need much changing of jet sizes. The slight hesitation is more related to pilot circuit and that circuit normally is in dire need of cleaning. I would replace the pilot jets. Tell me what your current jetting is, and maybe I can help.
