bad throttle response
- BarMan
12 Jul 2007 13:32
bike starts up and idles good... when i twist the throttle, rpms go up and stay up there after i let go... points?
- Frank
Re: bad throttle response
12 Jul 2007 14:07
Vaccum leak. Carb holders are cracked or loose or a vaccum port could be unplugged.
- almarconi
15 Jul 2007 21:41
Check to make sure that your throttle cables are adjusted properly. Also the return spring on the carbs
may be weak, not allowing the throttle to return. Try disconnecting the cables and operate the butterflys by hand to see if the problem goes away. I noticed on my KZ550 that if the cables don't have the proper adjustment in them the engine will do all kind of weird things.
1981 KZ550C LTD (SOLD)
1980 GS750L
1982 KZ750N1 Spectre (New Project)
1980 GS750L
- wiredgeorge
16 Jul 2007 06:23
The throttle cable tip is a good one... it is unlikely a return spring issue on the BS34 carbs as there are three separate return springs and never saw these go "bad" or loose tension. The tip on air leaks is also a good one. On older sets of BS34s I would also add that the orings on the mixture screws harden and tend to leak air and should be replaced. The other places suggested for checking are correct... just adding one more.
