Curious as to part on one carb
- Virii
- I like cheese
06 Jul 2007 14:09
Looking through ebay listings for carbs, I'm curious as to what that extra object is on the bottom of the second carb. I've seen it on a couple of carb sets but don't have it on mine...
This is the listing
Fuel regulator?...*shrug*
Post edited by: Virii, at: 2007/07/06 17:10
This is the listing
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- BSKZ650
Re: Curious as to part on one carb
06 Jul 2007 14:27
thats a accelerator pump, from what I have heard, they used them to help make epa ratings, the carbs ran leaner jets
77 ltd1000, current rider
76 kz900, just waiting
- katjbus
06 Jul 2007 15:13
accelerater pumps are to aid in transistion between circuits and to give you better quick throttle response
- Virii
- I like cheese
08 Jul 2007 10:50
Interesting, thanks! I always thought the pumps were on all carbs, not just one.
- wiredgeorge
08 Jul 2007 16:16
The pump (SINGLE PUMP) squirts gas into all four combustion chambers since the float bowls are linked to the pump circuit and there are nozzles in each of the four venturi. The pump squirts ONCE when the throttle is opened a bit... this is to add gas between the idle circuit and needle jet (mid-range) taking over... it is to cure the leanness used to meet EPA emissions testing in the late 70s. No catalytic converters yet I guess.
- Virii
- I like cheese
09 Jul 2007 08:15
Ah, makes sense. I'd wondered, thank you for the info!
