Mikuni BS34 CV carb jetting
  • Ozzy
  • Ozzy's Avatar Topic Author
02 Jul 2007 12:33
#154276
Ok, here's the speck,
KZ1000K2 engine with standard cams, 1075 wiesco big bore kit, head has been gas flowed and ported with oversize exhaust valves. K+N individual filters fitted to the standard mikuni BS34 CV carbs.
I need to get the engine run in before I can put it on a dyno to get the carbs set up right. Does anyone know roughly what size jets to use as a starting point so I can get it run in ?
  • rpkaw
  • rpkaw's Avatar
Re: Mikuni BS34 CV carb jetting
03 Jul 2007 18:40
#154563
Do you still have the stock airbox? The bs 34's are a vacuun slide carb and will prefer the airbox to the pod filters. I have an 82J with 1135 wiseco's, stock airbox with k/n filter and 34mm carbs with 135 mains.The main jet needle raised half a circlip notch.
I was using k/n individual filters and ended up running the 34's with 145 mains.Was never happy with the performance of the pod filters and went back to the airbox setup.
  • wiredgeorge
  • wiredgeorge's Avatar
04 Jul 2007 09:34
#154675
The point of putting a bike on a dyno (rather than an exhaust gas analyzer) is to set the main jet size. Your bike will do fine with #142.5 mains and #40 pilots and the stock jet needles with no shims. That will be very close to correct for your set up.
  • Ozzy
04 Jul 2007 09:41
#154677
:) Thanks for the info. I will let you know how it goes.
Ozzy...
