kz650 questions
- kc5deb
kz650 questions
01 Jul 2007 09:33
I have a 1978 kz650 B. I have just put the individual air cleaners (pods) on it, and have a few questions as to what to do with some extra hoses that are now not going to anything.
The big hose that comes from the front that went to the top of the air box; I have put a round filter on the end, and have it looking rather nice underneath the seat. Should I keep it the way it is, or plug it off?
The hose that came from the transmission, and did an "L" to the bottem of the airbox; I have a temporary hose running up to underneath the seat; can I just plug the hole off, or put a smaller filter on the end of the hose I was planning on buying?
Thanks in advance!
Thanks in advance!
- Mark Wing
Re: kz650 questions
01 Jul 2007 09:43
I'm pretty sure you can block off all the hoses.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- rstnick
Re: kz650 questions
01 Jul 2007 10:33
You can't block off the crankcase breather, the little L that went to the bottom of the airbox. Either put a small filter on it or a hose running down behind the engine. Filter's best though, because you don't want any excess oil getting on your back tire.
The two hoses/ports from the valve cover can be connected together, or you can buy block off plates that fit on top of the valve cover.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- rstnick
Re: kz650 questions
01 Jul 2007 10:35
If you do have these emissions hoses from the engine on top, you must have a '79 or later model, I believe. Or an engine from one at least.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- Mark Wing
Re: kz650 questions
01 Jul 2007 13:25
Thanks rstnick I was not sure what the third hose was that he was talking about. With a 77 I never had to worry about that smog crap.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
