pipe and carb issues
- oongow
29 Jun 2007 22:28
Hello,
I have got back into the KZ world and have bought a 1978 KZ1000. Questions are:
1. I am replacing the the 4 into 2 with a 4 into 1. I need split collars or flanges or sleeves. The old exhaust had them welded onto the header. New header has a slight flange at end that will not allow 1 piece to slip over. Dont know where to get them.
2. Bike has K&N pods and has carb jetting issues. Currently has 115 mains, clip on position 2 and stock needles. It also stock needle? jet and air screw out 1 1/4 turn.
Has Dyna ignition. Elevation is about 2500 ft.
Any help would be very appreciated.
- reborn650
Re: pipe and carb issues
29 Jun 2007 22:40
Welcome oongow - Judging from your question, you seem to know a little more about these old bikes than some of the newer members. You'll find kzr a valuable resource and one of the best Z1-Kz suppliers is Jeff@ Z1enterprises. He has pretty much anything you need or will direct you to where you can find the parts needed. Jeff is also a walking encyclopedia of old K-bikes.
Might be a good idea to put your bike and location in your signature in case there are other members in your area that might be able to assist you in the future.
-1998 Jeep TJ Wrangler 4.0...
- oongow
29 Jun 2007 22:47
Thanks alot. Will check him out. By the way, I love the pig.
- reborn650
29 Jun 2007 22:55
oongow wrote:
Who says Jack Daniels and bacon aren't a good combo?
- KZQ
- Administrator
30 Jun 2007 13:57
Hey oongow,
I moved your post over to the tech side, perhaps you'll get more traction over here.
If you've got a pipe that one piece flanges won't fit over something's really wrong. I suggest that you find some stock exhaust flanges and see if they won't work. I can't imagine that they wouldn't unless you've got a really strange pipe you're trying to mount.
Never heard of two piece flanges.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Z1Boise
30 Jun 2007 15:00
My Kerkers have a two piece thingy that goes around the pipe, and the flange presses on them. Maybe that's what he's referring to.
- oongow
30 Jun 2007 21:14
Yes, that is what i'm talking about. I heard that the kerker used these. The pipe is a Marving from Americanclassix.com. They show split sleeves or thingies or whatever on their site but you have to buy the flanges and all at a buck fifty ($150)I did cut the sleeves off the old pipes today with some success. I am getting some leaks at the cylinder as I had thought I needed to shorten the sleeves. The more beer, the shorter they got. Pipe sounds and looks gret other than needing the new ones.
