KISS
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
KISS
28 Jun 2007 21:18
#153556
Hi Folks,
I've been struggling with tuning the carbs on my KZ1300 for months. At first I thought that I had blocked up idle circuits. Then I thought that I had the carbs out of sync. Last night I decided that I'd pull off the carbs one more time to be sure the emulsion tubes weren't clogged up.
Now, I knew that the fuel petcock was allowing a very small dribble. I thought that it was nothing that the float valves couldn't handle. But tonight when I pulled the carbs off I saw that Numbers 1,2,3 &4 had fuel sitting in the intake boots. I've known for some time that cylinders 5&6 have been running fine with the other four running rich to fouled. Didn't occur to me that the reason 5&6 didn't have the same problem is because while sitting on the side stand the fuel was dribbling into the lowest four cylinders. I took the carbs apart any way, just to be sure. At this point I could put these three duces back together in the dark.
I found nothing out of the ordinary in the carbs. I decided to clean the plugs and fit a temporary tank to the bike and go for a ride. Sure enough, once I got it up the temp every thing smoothed out. No more surging and no stumble off of idle. I made sure to run the carbs dry before putting it up for the evening. I'll be looking for a new petcock in the morning.
The simplest things.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • PLUMMEN
  • PLUMMEN's Avatar
Re: KISS
28 Jun 2007 22:22
#153569
i thought i was the only one who did that!:P
  • Mellvis
  • Mellvis's Avatar
Re: KISS
29 Jun 2007 07:20
#153597
I know a guy that recently bought a bike for his wife and cleaned the carbs because itwould die after running for a few seconds. When reassembled, it did the same thing. Who could have known a gallon of gas could be so helpful???
