Float bowl gasket problems
- road_rascal
28 Jun 2007 18:09
I bought 4 rebuild kits from K&L for my '82 KZ750H LTD. I took everything apart, cleaned every jet and air passage I could find, and put everything together. I'm still having problems with the #1 carb (another story). Now, it looks like the float bowl gasket has grown larger by 1/8" or so. WTF? Do I have to buy another gasket or is there some trick to shrink it? Thanks. I've been browsing the forums and there's a lot of great info here.
- JR
Re: Float bowl gasket problems
28 Jun 2007 18:51
Been there and done that. Some of these gaskets which are more like large O rings and I'm assuming thats what you have, are pretty crappy. They swell up when in contact with gas
My trick was to put each one in a separate little ziplock bag and throw em in the freezer for 20 - 30 minutes. They will shrink down. Get your bits ready, remove from freezer and put them in one at a time. Work fast on each one before they swell back up.
Good Luck
Good Luck
- road_rascal
28 Jun 2007 19:16
Ya know, I tried that, but I didn't put them in ziplock bags and only set them in the freezer for about 10 minutes. I'll try it longer. These gaskets are shaped like the float bowl (I have seen the kits with just the large o-rings- what a pain that must be to install). Thanks for the tip.
