KZ 750 petcock
  • Invicta 39
  • Invicta 39's Avatar Topic Author
KZ 750 petcock
27 Jun 2007 20:29
#153311
The petcock on my KZ was not working and dumped fuel into my crankcase, thanks to this forum I found a great parts place and put the new diaphram in today. I have not put the tank back on the bike yet because I had a small amount of fuel left in the tank and this was leaking out of the gas line hose. I made sure that it was not on prime but it still leaked. Does the tank have to be all hooked up to make the vacuum work and stop the flow? Or have I not put it together correctly?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: KZ 750 petcock
28 Jun 2007 04:48
#153346
If vacuum is NOT applied to the diaphragm, then gas should NOT come out the gas spigot. I suggest you buy a Pingel adapter plate and get a gravity petcock that has a positive fuel cut off in the OFF position. Change your oil as that gas went somewhere when it flooded your combustion chamber.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
28 Jun 2007 05:56 - 03 Dec 2008 10:19
#153355
del
Last edit: 03 Dec 2008 10:19 by JMKZHI.
  • Invicta 39
Re: KZ 750 petcock
28 Jun 2007 07:14
#153377
1982 KZ 750 R. I got the kit from Z1 enterprises and it looks identical.It appears to be a good quality kit and they were very helpful and knowledgable.I have changed out the oil and cleaned the filter and it all looks good. I am assuming that it should not leak even when the tank is off the bike, correct?
  • JMKZHI
  • JMKZHI's Avatar
Re: .
28 Jun 2007 08:13 - 03 Dec 2008 10:22
#153388
del
Last edit: 03 Dec 2008 10:22 by JMKZHI.
  • Invicta 39
Re: KZ 750 petcock
28 Jun 2007 09:42
#153410
I will try that and see what happens. Many thanks,GGJB.
  • GPzDave2
  • GPzDave2's Avatar
Re: KZ 750 petcock
19 Jul 2007 21:29
#158171
wiredgeorge wrote:I recently purchased a rusted but salvagable 1978 kz750b3. It has the stock PC rusted to the tank and a new replacement PC in a box of loose spare parts. Both are vacuum operated. I know from experience that the older vacuum pets are pretty much junk. My yammi xs750f is imfamous for gas/oil from leaky PCs. On that bike i replaced with stock gravity fed PCs from an xs650. Question is: what would be a good gravity fed PC that, along with a pringle adapter, would work the best with the kz750? Any ideas would be appreciated.
  • GPzDave2
  • GPzDave2's Avatar
Re: KZ 750 petcock
19 Jul 2007 21:31
#158172
oops...actually i wrote that last missive, not wiredgeorge...
  • Qdude
  • Qdude's Avatar
  • It is all good.
Re: KZ 750 petcock
20 Jul 2007 09:11
#158256
I bought a Suzuki diaphram petcock after messing with mine for too long unable to get a replacement. Works!
Lots of options out there. (Sorry purists....)
77 KZ 650 C1.
77 KZ 650 C1.
