a couple of carb questions
- stevoe
15 Jun 2007 19:56 #149840
by stevoe
a couple of carb questions was created by stevoe
i recently purchased a 75 kz 400 d. it has a 400 s motor in it according to the numbers.
the motor is running really lean. the plugs are white and it runs much better with the choke on then without. it has keihin carbs on it that im assuming are cvb 36's. the manual says that it comes with a 130 main jet but it has a 125 in it.
my question is. where do you get these jets from? ive searched all over the net. i also went to my local shop and they said they werent available. if these jets are no longer available. could i just drill them out? what does the 125 mean? is that metric?
thanks in advance.
thanks in advance.
- onuLine57
15 Jun 2007 20:15 #149850
by onuLine57
1978 KZ650 B2A
Cincinnati, OH
Replied by onuLine57 on topic a couple of carb questions
Look at Z1 for parts. They have the rebuild kit for the carbs which come with the jets.
www.z1enterprises.com/detail.aspx?ID=1869
1978 KZ650 B2A
Cincinnati, OH
- stevoe
15 Jun 2007 20:51 #149864
by stevoe
Replied by stevoe on topic a couple of carb questions
those kits are no longer available.
- ibsen22000
- Thank you received: 1
15 Jun 2007 20:58 #149866
by ibsen22000
Replied by ibsen22000 on topic a couple of carb questions
www.cyclewareables.com/pages/keihin_main...n_main_slow_jets.htm
Scroll down to PRESS-IN MAIN (SECONDARY) FOR KEIHIN
- stevoe
16 Jun 2007 09:32 #149956
by stevoe
thanks. ive ordered them.
