carb id
  • arobsum
  • arobsum's Avatar Topic Author
carb id
28 Dec 2005 15:00
#14911
how do you tell the difference between vm29's and 33's? thanks for the help.
  • DanOz7Five0
  • DanOz7Five0's Avatar
Re: carb id
28 Dec 2005 15:47
#14917
Cant you just measure the inner diameter on the air cleaner side?
Im sure someone knows more but thats where I would think the easiest place to start is
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: carb id
28 Dec 2005 16:08
#14922
The carb tops are very different. The 29mm carbs use the same top as found on all the KZ900 and all the 77-80 KZ1000 KZ650 carbs.
You'll see from the gaskets the how different they are.
www.z1enterprises.com/SearchResult.aspx?...&KeyWords=carb%20top
  • arobsum
Re: carb id
28 Dec 2005 16:24
#14925
thanks. i could definitely tell from the gaskets. i appreciate the help guys, thank you.
