- Thank you received: 1
77 KZ650C Circlip and collar?
- Virii
- I like cheese
13 Jun 2007 15:20 #149093
by Virii
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
77 KZ650C Circlip and collar? was created by Virii
I'm missing a plastic collar and circlip for the enricher on one of my carbs. For some reason, I just can't find anybody that selling one tiny little circlip with a label saying "this is the circlip for the 77 KZ650 that you've been looking for".
Darnedest thing...
Still starts right up with no hesitation or problem but....I know it's missing and that's been on my list for months.
I wonder if anybody has any leads or a spare carb laying around they'd like to sell or trade for something comparable?
Darnedest thing...
- Duck
- e vica na i sau na ga
13 Jun 2007 15:26 #149097
by Duck
Replied by Duck on topic 77 KZ650C Circlip and collar?
Don't know abotu the plastic collar but a well stocked hardware store should have the circlip.
- wiredgeorge
14 Jun 2007 05:59 #149258
by wiredgeorge
Replied by wiredgeorge on topic 77 KZ650C Circlip and collar?
A fella who owns a shop in Maryland named Fischer I think sells the little spools made out of aluminum. He sells them in sets on eBay and probably sells them via his shop. He does have a website but I can't recall what the link is. He used to hang out here but haven't seen him in ages. You might look on eBay... not sure what to search for but I have seen them either searching for KZ parts (usually search "KZ1000") or for "carburetors".
As far as the E-Clip (not a circlip), it is metric 2.3mm - if you find the fella I suggested, he probably has those as well. I buy them by the hundred from a supplier. Unfortunately, you can't make an inch e-clip work as the inch-sized clips are a tad too small or too big. This e-clip (2.3mm) and 4mm e-clips are used on many carbs and a few use 7mm such as the ones on the end of throttle shafts.
- mariozappa
- Thank you received: 8
14 Jun 2007 06:30 #149268
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic 77 KZ650C Circlip and collar?
1977 KZ650C1
- Virii
- I like cheese
14 Jun 2007 09:25 #149314
by Virii
Replied by Virii on topic 77 KZ650C Circlip and collar?
Thanks for the heads up, everybody! I do see a set of carbs on ebay for what seems to me to be a decent price. I assume I can just harvest the parts I need from it. Out of curiosity, is there much difference in the designs of the carbs used for these bikes? I've seen mention of numerous different models while digging through previous posts but was never truely clear on the differences.
- Rickman
14 Jun 2007 11:34 #149351
by Rickman
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Replied by Rickman on topic 77 KZ650C Circlip and collar?
by 'these bikes' you mean KZ's? I would say, hell yes; KHI seemed to use just about anything. check out some of the different styles in the pictures on wiredgeorge's site sometime.
