- Thank you received: 1
smoothbores
- K-man
- Sandy
- Fly High,Tony
- Thank you received: 13
1977 KZ1000 A-1
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- katjbus
- Thank you received: 3
- Duck
- e vica na i sau na ga
as
catfish dinner : man
- roy-b-boy-b
- Thank you received: 103
I think George got a little over $600.00 for the last set i saw him list on eBay.
They are super responsive. Roy
Post edited by: roy-b-boy-b, at: 2007/06/14 22:59
- Mark Wing
I believe that they have a rectangle slide instead of a round one and the bottom of the slide is solid, not recessed like a round slide so when it is wide open throttle it is smooth so there is no eddies cause by the slide edges, also the midrange pipe where the slide needle goes into is flush with the venturi, hence the name smooth bore.so they just flow bvetter all around and are typically very pricey. but I could be off base.
The one's I have are the old round slides. The body's are cast wit a roof so when the slides are all the way open there's no hole in the top to mix up the air flow. I've herd the 29's when wide open flow like 31's but are more responsive at lower R.P.M.'s then bigger carbs would be on the same bike.
Mark
Yorba Linda Cal.
- ZeeEuro
and also can all of the above fit a 650C3 or are some of them incompatible?
Thanks!
- Mark Wing
Mark
Yorba Linda Cal.
