setting carb float levels with water
- rckz
09 Jun 2007 21:07
I'm tired of inhaling volatile organics and getting them all over myself. Has anybody ever set their float levels with water instead of gas. I was thinking I could set the lever a bit lower than usual to account for the higher density of the water relative to gas. Dumb idea?
- 76LTD
Re: setting carb float levels with water
09 Jun 2007 21:53
Stick to gas. You don't need to introduce water to the insides of your carbs.
You can wear gloves and keep the area vented to keep your exposure to the gasoline down.
- ronjones
10 Jun 2007 06:39
I agree w/76LTD about introducing water to the carbs. However I used 90% rubbing alcohol, to do my bench adjustment, seemed to work fine. I wouldn't leave the alcohol in it for any length of time, as I don't know what it would do to the rubber parts.
Ron
Ron
- N0NB
- Blue handles better
10 Jun 2007 06:45
A little gas on the fingers never hurt anyone! I'm living proo
Acck!
Cough!
Wheeze!
:S :sick: :woohoo:
I have a small gas can that I can attach the fuel line to and run fuel into the carbs. Then I use a small water bottle to catch the drain out and pour it into the other gas can. I hardly ever touch the gas. But then I'm using my custom carb holder.
Acck!
Cough!
Wheeze!
:S :sick: :woohoo:
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
