vm24 is a vm24 right?
- anarki650
07 Jun 2007 11:55
Anyone here ever rebuilt the vm24s with accelerator pumps? I just went to get kits for my new project and the parts store didn't list kits for anything newer than a 79 kz650 (which if I remember correctly used the accelerator pumps on). Sooo, a vm24 is a vm24 right? All the needed bits should be in the kits for any of them right? I know the parts for the accelerator pump won't be in the kit, but I should get everything I need for the carbs right? I've already torn down the carbs and they look the same inside as the 24s on my 77 (sans accelerator pump), so I'm thinking I should be good using the same kits. Anyone know differently?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- mariozappa
- mariozappa
Re: vm24 is a vm24 right?
07 Jun 2007 12:36
Oops!
I just I should answered you question, huh?
The K&L rebuild kits say that it cover the carbs on the KZ650's B1/B2/B2A/C1/C2/D1/D1A.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- anarki650
07 Jun 2007 20:55
Thanks! I was assuming that the kits would be the same because the carbs look the same (minus the accelerator pump).
09 Kawasaki ER6n
Omaha NE
Omaha NE
- Bluemeanie
09 Jun 2007 07:40
They do and they don't! I looked and looked but all I found were carb kits for 77-79. NEVER came across kits for a 80 model. Very frustrating for sure, so went ahead and got the "regular" kits. Most of the stuff worked EXCEPT, float bowel gaskets did not have passage for vacuum for accel pump, (found seperatly) new pilot screws would not work as mine has "air screws", other than that they are the same. Would still like to know why kits stop at 79.
