KZ750 Twin: idle and popping problems
- al_ndsu
05 Jun 2007 07:27
I recently cleaned my carbs and put them back on. My bike is running lean (I've checked the plugs and they are white.) Reading other posts I keep hearing to adjust the air pilot screws and put them all the way in and back them out 1 1/2 turns, or check the intake boots.
My air pilots screw don't even go around once. There is a catch and you can only turn them like 180 degrees.
I've checked the boots and there are no cracks and they look fine. I'm going to try the WD-40 trick tonight. I'll attach a picture of the air screw and the catch if no one knows what i'm talking about.
Also I'm looking for an oil and air filter for the 79' twin. Does anyone know of a site? I've been reading posts for about a month and can't find a solution.
THANKS!
THANKS!
- Biquetoast
- King Jeremy The Wicked
Re: KZ750 Twin: idle and popping problems
05 Jun 2007 11:12
al_ndsu wrote:
...oh, and welcome, fellow twin owner!
Post edited by: Biquetoast, at: 2007/06/05 14:15
Yep, that's lean alright!....My bike is running lean (I've checked the plugs and they are white.)
Mine are actually a bit more. My pilot screws are 5 x 1/2 turns out (that's 2 1/2 total turns, but I keep mental track by half-turns)Reading other posts I keep hearing to adjust the air pilot screws and put them all the way in and back them out 1 1/2 turns, or check the intake boots.
That's bad. I wonder if you're turning the wrong screw. Pics will help.My air pilots screw don't even go around once. There is a catch and you can only turn them like 180 degrees.
Good.I've checked the boots and there are no cracks and they look fine. I'm going to try the WD-40 trick tonight.
Good.I'll attach a picture of the air screw and the catch if no one knows what i'm talking about.
www.z1enterprises.com ... here's a tip. I but the Fram filters once-in-a-while because they include the figure-8 shaped o-ring you need for the oil filter. But Fram filters are kinda garbage (my opinion), so I never run them much; I usually use the emgo ones, but they do not include the 8-shaped o-ring...Also I'm looking for an oil and air filter for the 79' twin. Does anyone know of a site? I've been reading posts for about a month and can't find a solution.
THANKS!
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- ronjones
05 Jun 2007 13:32
Hey Toast, that's a good tip. When I started my rebuild I had a new filter I'd bought 12yrs ago, and used that and it had a fig8 o-ring, but I forgot what brand. Since I've had to buy another and it didn't have the oring, so I thought they no longer put them in. Now I know I need to get a Fram every once and awhile. Thanks.
Hi, Al_ and welcome. I didn't reply to your post earlier because, I think our carbs are different, and didn't have anything intelligent to offer:pinch:. Still can't :blink:
except that Toast's advice is right on. What mods do you have? Pods or AirBox? Most post 78 carbs came w/a plug in the pilot adj screw access hole, so you wouldn't mess w/the needle adjustment/emissions setting. Your's may have a limiter instead of a plug, which like the plug can be removed to get access to the pilot adjuster. Since you have already cleaned the carbs and since you haven't removed the pilot screw to clean that, there could be a problem there? Nice having another Twin in this crowd of Quads
Welcome again and good luck.
Ron
Post edited by: ronjones, at: 2007/06/05 16:35
Ron
- al_ndsu
06 Jun 2007 07:40
I figured out the air pilots. There was a plastic piece that I had to pull off the screws before I could adjust the jets. It's really tricky becuase they make them look like screws but they're not. Tricky...tricky. They were pretty much all the way out. So I got it running WAY better now. It's amazing how, if your bike isn't balanced it loses so much power. It's a rocket compared to what it was before. Runs like a top. I'm not that mechanically inclined. I started with mopeds and moved up to bikes.
I do have one question though. One of the bolts on the engine case was stripped when I bought it and know leaks oil due to the lack of a solid seal. Does anyone know where I can find a replacement. I also need new jets.
Thanks for the help!
- Biquetoast
06 Jun 2007 08:16
Glad to hear you made progress!!!
al_ndsu wrote:
al_ndsu wrote:
If you mean the HEAD is stripped, you can buy stainless, hex-headed screw replacement sets (for both side covers, etc) for those #3 phillips monstrosities. If you mean the thread is stripped, well then, you'll need a Helicoil or Recoil tap and insert kit..........One of the bolts on the engine case was stripped when I bought it and know leaks oil due to the lack of a solid seal. Does anyone know where I can find a replacement...
Can't help you with jets, sorry. In fact, I hear they're hard to find for these bikes, but I really don't know......I also need new jets...
kz750twins.com
kz750twins.com
