rs 34 flatslide knock
- wallyworld
31 May 2007 16:50
I just put on some rs 34 flatslides, and they run great.The only problem is the slides are alittle loose and knocking at certain rpms [with the pulse of the engine] any of you guys ever expriance the knocking slide blues?if so ,whats the cure? and don't say whiskey. thanks
i
i
- fastestz1
Re: rs 34 flatslide knock
31 May 2007 20:47
thats "clacking" it should be music to your ears.
- tbax
31 May 2007 21:16
If their not "clacking" then somthing is wrong. Normal operation.
- mark1122
- Keep twisting it
31 May 2007 22:17
did you notice any improvement in performance over the vm33's?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wallyworld
01 Jun 2007 13:37
thanks for the good news guys, that clacking was really starting to bug me.I won't have to worry anymore.
the 34 rs flats are a big improvement over the 33's,mainly on rollon, the 33s were always alittle lean when giving it the onion.my rs's are alittle rich right now as I don't have the right needle jets[i'm using the nj's from my rs 40's]the bike gurgles once in awhile,but other than that it runs better than it ever has.
- oldkaw79
01 Jun 2007 16:29
I run 36's with a 1075,.425 lift cams and a big ported head with big valves, they work great. I thought they might be alittle to big but they work great. Pulls real hard on top and the mid range is real good with not flat spots.
