pilot screw settings
- skydailey
31 May 2007 08:07
1977 KZ 650b1 I have the carb air screw out 2.5 turns. How many out is too much before changing the Idle Jet to a larger size. Also, anyone know the stock settings on the air screw??
- StreetfighterKz
Re: pilot screw settings
31 May 2007 08:45
If you have an air screw, it works opposite of a fuel screw. The more you turn an air screw out the leaner the mix and the more you turn it in the richer the mix.
If you have a fuel screw then I've heard that more than 3-3.5 turns out its time for a bigger pilot. I've also heard that when you're 0-1 turns out you need a smaller one so anything from 1-3 is pretty acceptable.
I think every screw is set different but I've always started with a baseline of 1.5 turns out for both fuel or air screw. That way I'm kinda in the middle of the range.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
