Lube!
- paulie
Lube!
30 May 2007 17:43
My manual says to lightly "grease" the throttle valves before putting them back into the carbs. what kind of stuff should I use? the manual never says the type.
also, my starter plungers are quite sticky, what should i use to lube those? same stuff as the throttle valves?
thanks in advance guys
- wireman
Re: Lube!
30 May 2007 23:00
wireman wrote:
me neither
ive never put anything on carb slides;)
me neither
- katjbus
Re: Lube!
30 May 2007 23:05
I never have either, just remove the plungers and clean really well with carb clean, if everything is clean and in good shape they should operate smoothly
- paulie
Re: Lube!
31 May 2007 06:27
thanks guys!
i didnt end up lubing the valves/slides, but i did have to dab some 3-in-1 on the plungers, and now theyre nice and smooth. the problem was that without the lube, the plungers only worked if they were being pulled totally straight up. as soon as i put the carbs onto the mounting plate and tried to move them with the choke lever, they would bind up. a little lube on the plungers fixed that up nicely.
again, thanks for all the replies!
wish me luck, this is my first carb rebuild. everythings gone smooth so far, with a little help from a friend :whistle: tonight its carb sync, and then hopefully tuning!
Re: Lube!
31 May 2007 13:13
paulie wrote:
Should do ALL other tuning before carb sync. This is because carb performance relies on proper ignition and valve settings. In other words, it's best to have everything else spot on before addressing the carbs.
...tonight its carb sync, and then hopefully tuning!
- paulie
Re: Lube!
01 Jun 2007 07:39
woops! sorry, my newbie-ness is showing!
by tune i was referring to the carbs! idle speed, mixture, etc. you know, the stuff you do with the carbs actually on the bike
- kzwolfsr
Re: Lube!
01 Jun 2007 08:33
I have this carb cleaner I clean my carbs in call Gumout carb cleaner which has some lube in it. I dip the carbs in it right before assembly so the slides slip in easy and they are dustless and no dirt is on them.
Original man of the Caribbean
