GPZ 1100B2 fuel infection problem
  • jcote75
  • jcote75's Avatar Topic Author
30 May 2007 07:23
#144839
Hi,
My bike stop after maybe 2 or 3 minute of running. Once it's get hot in fact.
I've start checking what could be the reason last night and saw that wire going to a sensor were cut. This is the sensor install on top of the air box. I presume it's an air sensor......
Part number is A25-000-004
Does somebody know if this could be solve my problem and is this parts still available?
Many thanks,
Joce
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: GPZ 1100B2 fuel infection problem
30 May 2007 09:04
#144863
Joce, if you don't get an answer by this afternoon/tonight, I'll do some sleuthing for you...my literature and GPz are at home:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
30 May 2007 11:03
#144896
jcote75 wrote:
Hi,
Many thanks,
Joce
Some penicillin will kill that infection and stop the rnnning.
The sensor in the airbox on the 82 is for air temperature.
The computer uses engine temp, air temp, and throttle position to time the injectors which sets the mix.
With sensor connected, blue(pin 6 on control unit) to battery negative should read 0V with ignition off, 2-3V with switch on at 20C, 1.7-2.5V with switch on at 30C. Blue/red(pin 5) to battery negative should read 0V at all times. With sensor disconnected the blue at pin 6 should read 3.4-4.6V
AFAIK it should run rich(thinks air is cold) without the sensor but I could be wrong. I'm just getting around to putting my 82 GPz together.
-Duck
  • jcote75
30 May 2007 11:27
#144905
Ok.
so from what I understand, since my air sensor is not functionnal, the computer think the air is cold but it is not. In result, the mix is not correct which result that the engine stop.
This would be so fun to resolve my problem in a easy way.
Does somebody hace a spare sensor for sale?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
30 May 2007 13:38
#144959
Joce:
Check with any Kawasaki shop to see if the part is still available...I suspect it is, as it was in use until 1989 in various models besides the GPz. The part number = 21176-1003 and should retail for about US$50.00.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mcjsrt6
  • mcjsrt6's Avatar
31 May 2007 12:55
#145265
mcdroid. i'm a new guy with the same problem with an 81 gpz 1100. Is that part # the same for the 81?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
31 May 2007 13:44
#145283
Yes it is also used on the KZ1100B1, but I see from your signature that you have converted to carbs...why would you be worried about the air sensor?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mcjsrt6
  • mcjsrt6's Avatar
31 May 2007 19:11
#145354
mcdroid, i've got another bike coming and have a complete injection system with bad air sensor. winter project of making one carb and one injected. watched forum a while before joining. from what i've seen, wiredgeorge will be getting a call from me. i have some clutch questions also, but that will be down the road. thanks for the info. i'm in SW Missouri. last question for now. can the one way check valve returning to the fuel tank still be purchased from Kaw.
  • Duck
  • Duck's Avatar
31 May 2007 19:28
#145356
The mass flow sampling differs on the 81. I do not have my manual but IIRC it uses a flapper attached to a position sensor. The air density, which IIRC is a function of temperature to first order and humidity to 2nd, is sampled via the position of the flapper. I'll have to check the manual, not handy at the moment, but I do not recall any temp sensor other than the one in the head.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
01 Jun 2007 06:06
#145455
Are you speaking of the relief valve on the bottom of the fuel tank? 16130-1002? If so, then it is still available...just bought two through Jeff @ Z1Enterprises for about US$25.00 each (cheaper than Mother Kawasaki).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mcjsrt6
  • mcjsrt6's Avatar
01 Jun 2007 07:20
#145464
mcdroid, that's the one. thanks for the patience and help.
