Pilot jets for 1260 cc KZ
  • KruZer
  • KruZer's Avatar Topic Author
28 May 2007 17:20
#144344
Anyone have an idea of what pilot jet size I should use with the following comfiguration:
33 Mikuni smoothbores on a early model KZ1000 cases with a low compression (10.5 TO 1) 1260cc bigbore with Web #218 cams,(418 lift I believe)runing a J model head with stock valves?
Thanks,
Buzz:blush:
*1977 1000, 1975 KZ998 LSR bike.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Pilot jets for 1260 cc KZ
29 May 2007 06:06
#144479
Buzz, try #17.5 pilot jets with the air screws almost closed. No more than 1/4 turn open. This is for 33s with 1.5 slide cut outs. If you have larger slide cut outs, much larger pilot jets are needed.
  • KruZer
29 May 2007 10:30
#144554
Thanks! I'mm check the slide cut outs and adjust the air screws.
I really appriciate the info.
Buzz
