float height vm26
- archaicbiker
float height vm26
28 May 2007 13:08
I finally got around to pulling the carbs back off so I could reset the float heights. Everythings closed around here and so I cant get a 1/4 vac fitting. Anyone know what the measurement would be doing the static adjustment? Where you flip the carbs over and measure from the gasket seat to the tops of the carbs? I have the vm26 with acc pump on my 79LTD1000.
- archaicbiker
Re: float height vm26
28 May 2007 17:38
Two were set at 7/8 and one was just a bit less, and the other was less than 3/4. I think it was my problem carby. I set them all to 7/8 and shes running pretty good and also quit the idle drop when I put it on the side stand.:woohoo:
