full choke only
- Pijoe1
full choke only
24 May 2007 06:47
I have a 1981 kz550 ltd bike starts up fine and idles smooth at around 1100 rpms just sync carbs (tk models) after warm up bike idles fine with choke off but when taking off I must use full choke, bike boggs down when choke off after warm up can anyone help me!
- Sandy
- Fly High,Tony
Re: full choke only
24 May 2007 08:00
Welcome to KZR,Bud!
Can You tell Us a little more about the bike?
Have You had the carbs off? Does it have factory exhaust or factory airbox,etc...things like that.
How many miles?
The intake boots,at the carbs...do they appear to be cracked from age?You might have a leak in there somewhere,causing a lean condition.
Need some more info though,but it does sound like You might have a leak...somewhere...
How many miles?
1977 KZ1000 A-1
- Pijoe1
Re: full choke only
25 May 2007 18:05
bike is all stock, I had my carbs rebuilt and sync, this problem was happening before I did the rebuild but was riding rough, when using vacuum gauges to sync carbs is there a specific vacuum setting for the carbs to be within range? I will check carb boots for leaks also is there any other place to check?
Post edited by: Pijoe1, at: 2007/05/25 21:08
