KZ900 Carb Identification
  • moonwell
  • moonwell's Avatar Topic Author
24 May 2007 05:39
#143053
Can anybody help me identify these carbs on my KZ900? They don't match up with anything in my manual or in Z1's identification guide . I measured them to be 29.3mm and they have the accelerator pump. Wish they would just stamp a model number on them somewhere ;)
Click the thumbnails to enlarge. Thanks!
[img
[img
[img
[img
[img
[img
  • wireman
  • wireman's Avatar
Re: KZ900 Carb Identification
24 May 2007 10:49
#143116
29 smoothbores;)
  • moonwell
24 May 2007 11:01
#143121
wireman wrote:
29 smoothbores;)
Did they make more than one version of those, because they're different than the smoothbores shown on the Z1E site
[img
  • wireman
  • wireman's Avatar
24 May 2007 11:10
#143125
whats differant about them?;) the bottem bowls come in 2 styles for 29s,you can also use bowls from 26mm carbs on them if you want to be sneaky:whistle: :P
  • moonwell
24 May 2007 11:46
#143135
Yeah, the bowls looked different, which wasn't a big deal, it was the air inlet that looks quite a bit different between the 2. The Z1E photo has a bunch more little circular areas going around it than mine (whatever they all are...) that was throwing me off...
  • wireman
  • wireman's Avatar
24 May 2007 11:50
#143137
are the bodies made out of aluminum?thats another sign they are smoothbores,most stock carbs are cast in heavy ass zinc or something like that;)
  • wiredgeorge
  • wiredgeorge's Avatar
24 May 2007 12:51
#143149
There is an ID mark on the flange of the outside carb where the carb inserts into the bracket that holds the carbs. What is it? Those are not VM29 smoothbores. There are some things about those carbs that make me think they are VM26 w/pump that have been line bored but the 26 pumpers used pilot mix screws (on bowl on engine side) and those have air screws. They are 79 or 80 carbs as the deep set air screws came out in 79. They have most likely been line bored to increase the venturi diameter.
24 May 2007 12:58
#143155
Smoothbore has a jet block over which the throttle side moves up and down.
Do you have a pic from underneath with float bowl removed? Might see head of a small phillips screw used to hold jet block in place.
MEMO: Wiredgeorge cautions against removing the jet block as it invariably damages the delicate thin no-longer-available-virtually-impossible-to-duplicate gasket between the jet block and the carb body.
My 29's are as pictured on Z1E site, single large drain screw on bottom of float bowl, only a single fuel line attaching to a single fuel pipe joint located between the two inside carbs, and no accelerator pump.
Glad to learn about aluminum construction of smoothies and possibility of using different float bowls with overflow tubes. :)
EDIT: Posted before seeing WG's post. And in carb stuff, he more than qualifies as an expert witness. B)
Post edited by: Patton, at: 2007/05/24 16:04
Post edited by: Patton, at: 2007/05/24 16:05
  • moonwell
24 May 2007 21:47
#143302
This number? 120 2
[img
  • moonwell
28 May 2007 16:25
#144334
Anymore ideas on these carbs?
  • wiredgeorge
29 May 2007 06:11
#144483
I believe those are pumper carbs VM26SS from a 79 LTD that have been line bored.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
29 May 2007 08:25
#144519
George...could they be 28 pumpers that have been bored?
1977 KZ1000 A-1
