Torque Specs for Intake Rubber for KZ750 H2 LTD
- cafekz750
21 May 2007 18:35 #142169
by cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Torque Specs for Intake Rubber for KZ750 H2 LTD was created by cafekz750
I have an '81 KZ750H2 LTD that I have been working on recently. I fired up the bike and had a very high idle. I shot some starter fluid on the intakes and the idle increase on carb #2 (of 4). I took the carbs out and check the intake rubber. For cylinder 1 and 2 I could turn them with the screw driver easily. My parts bike engine required a impact driver to free the screws. What are the torque specs for the 2 screws holding the intake rubber to the engine?
- Sandy
- Fly High,Tony
- Thank you received: 13
21 May 2007 19:35 #142208
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Torque Specs for Intake Rubber for KZ750 H2 LTD
I would just apply some BLUE loctite on the threads,and even a THIN layer of high-heat silicone to the faces of the manifolds,and just tighten the screws by hand until they're tight.
If You DO use silicone,let it set up for a while first,before You tighten things down.This way You won't get silicone oozing out,into the head.
1977 KZ1000 A-1
