Microsquirt production
- Dave Sloan
21 May 2007 00:58
Hi Steel, did you see that the microsquirt is going into production?
Have a look at this
www.microsquirt.com/viewtopic.php?t=22713
Have a look at this
Z650B2 - Injected
- 77KZ650
Re: Microsquirt production
23 May 2007 12:43
so how much smaller will the unit be? maybe i should hold off for one? hmmm.....
edit. credit card sized that would be easy to fit... you fit a regular one no trouble where the air box was right Dave?
Post edited by: 77KZ650, at: 2007/05/23 15:48
07 MDP Rookie of the Year
- Dave Sloan
24 May 2007 00:37
Yep I have mine mounted infront of the battery box on a bracket that I made up and have the fuel pump and the fuse box and relays mounted on it aswell. I will take some pics on the weekend if you want?
Z650B2 - Injected
