Which carbs are these?
  • CruisingRam
  • CruisingRam's Avatar Topic Author
17 May 2007 20:14
#141130
Title say it all! 1982 KZ 1000 LTD
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Which carbs are these?
18 May 2007 06:00
#141193
Mikuni BS34
  • kzwolfsr
  • kzwolfsr's Avatar
18 May 2007 07:29
#141224
To add to WG's post, they are CV or constant velocity carbs. My manual says they can handle changes of altitudes like fuel injection and I guess don't need much jet changes
Original man of the Caribbean
  • udder
  • udder's Avatar
18 May 2007 07:49
#141240
yup those look like me bs34's but what is the hose off of the top the carbs????? i believe its just an access for syncronizing correct? mine just have sleeves over them.
  • wiredgeorge
18 May 2007 07:56
#141245
Geesh... constant velocity carburetors are far more fussy about needing to be rejetted for altitude or airbox/pipe changes. Altitude=Fuel Injection? HUH?
The hose on the #4 carb vacuum fitting is connected via a tee to the one on the #1 carb and those connect to the vacuum switch which opens the reed valves on the valve cover... emissions control stuff.
  • kzwolfsr
  • kzwolfsr's Avatar
18 May 2007 08:26
#141257
No WG, I meant they sense vacuum and adjust to which fuel/air mix you need at different altitudes, the mechanical way to how cars today sense how much air comes in the intake and matches the fuel to it. I am trying to make the point but I don't know if I did yet.
  • CruisingRam
18 May 2007 09:12
#141267
So tell me- can I run pods on it without screwing up tuning too much?
  • wiredgeorge
18 May 2007 11:08
#141315
Yes, you can run pods. You need to rejet. If you look on the side of the jet needles, I can take a guess as to how to rejet. Some of the 4xxxx jet needles are real rich compared to others in both the 4xxxx and 5xxxx series. The richer jet needles require #130 mains for pods plus #40 pilots (type BS30/96). The rest of them require #140 mains and #40 pilots. I only mention this because I think Canadian models have the richer jet needles but can't say for sure. I suspect your j bike could be a Canadian model?
  • CruisingRam
19 May 2007 10:53
#141511
I will have to research it- it could just as easily be a japanese/euro spec bike up here, I would have to see what dealership it might have been sold at in time- the Kawi dealer here "back in the day" didn't always get American spec bikes, we frequently got Euro or Jap spec bikes- like the japanese spec Z1 that is actually a 750? IIRC. We have a few of them,
on top of that, we have military dudes bringing what would normally be "grey market" bikes here.
  • wiredgeorge
19 May 2007 13:15
#141540
The Japanese model that is the same as the Z1 but is a 750 is a Z2 (not a Z1).
